15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years agoCould you sample more bits, so that we can see the full message? You can use a slower clock to sample the bus, the MDIO clock is supposed to be <= 2.5MHz
I find it strange that the driver doesn't prinf anything about the PHY. And where does the 123456789 come from? Could you run the PHY exploring routine in a debugger, to see what it does?
