15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years agoThank you Daixiwen, I have put a screenshot of my Signaltap in the following PDF (sorry I couldn't upload anything else because of the firewall)
Everytime I have my Simple_socket_server working I have the following messages: InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Can't read the MAC address from your board. We will assign you a MAC address. Please enter your 9-digit serial number. This is printed on a label under your Nios dev. board. The first 3 digits of the label are ASJ and the serial number follows this. -->Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) 123456789 123456789 Your Ethernet MAC address is 00:07:ed:ff:cd:15 Static IP Address is 0.0.0.0 prepped 1 interface, initializing... [tse_mac_init] And since I'm using the PCIe port of my board (which is plugged on my motherboard) I can't really see LED blinking for the Gigabit Mode. But I'm quite sure that none of these LED are blinking. I also tried to disable the DHCP mode in my software but it comes to the same thing in the end. Again thank you for helping me.
