17 years ago
Stratix III Dev kit ethernet problem
I am using the Stratix III dev kit:
http://www.altera.com/products/devkits/altera/kit-siii-host.html
and I have programmed the board with the correct NIOS II standard design. I am able to run all of the sample projects on the NIOS II(hello_world etc.), but I cannot get the simple_socket_server (or the web server) to work.
Compilation and download look fine, but an error is returned when the PHY is initialized.
The message returned in the IDE looks like this:
Your Ethernet MAC address is 00:07:ed:ff:f6:fe
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x00001400
ERROR : MAC Group[0] - No PHY connected!
ERROR : PHY[0.0] - No PHY connected! Speed = 100, Duplex = Full
OK, x=161, CMD_CONFIG=0x00000000
On the board, both the Tx and Rx LEDs are off, and the hub that I am plugged into also does not indicate a connection.
I reinstalled the Dev kit software, as well as the hardware .sof file to verify that I had not inadvertantly messed anything up, but the problem is still present.
Does anyone have any ideas or pointers on how to debug this?
