17 years agoStratix III Dev kit ethernet problem
I am using the Stratix III dev kit: http://www.altera.com/products/devkits/altera/kit-siii-host.html and I have programmed the board with the correct NIOS II standard design. I am able to run al...
17 years agoI too am experiencing the exact problem as djw posted. I too am using the V8.0 Stratix III dev kit with the example "standard" design for the SIII board. I wonder if v9.0 would fix it, but there doesn't seem to be anywhere to download it.
I have downloaded the example that naceradsky posted, and while that does work, it is not really clear what has been done there to fix it. While it works, it doesn't really help me for creating my own design. The DOC file describes how the NIOS project was changed, but there have also been changes to the Quartus/SOPC side of things. Googling has drawn a big blank (apart from this thread). Would some kind person be able to point me in the direction of information on what the issue is here and how to fix it?
