17 years agoStratix III Dev kit ethernet problem
I am using the Stratix III dev kit: http://www.altera.com/products/devkits/altera/kit-siii-host.html and I have programmed the board with the correct NIOS II standard design. I am able to run al...
17 years agoHi all,
no need to say that I'm experiencing the same too. I'm playing a webserver example application. Thanks very much to naceradsky, you project seems to work fine, at least until I don't generate system and compile by myself. When I do, I have a problem and something unexpected (problems are always)... The unexpected is that compilation generates two .sof files the standard one and one called _timelimited.sof or something like this. System ID is not compatible with the one from NIOSIDE with the standard .sof file, have to load the time limited one (I have a full license). Anyway it doesn't desturb me too much but I would have a more clear idea on this point if someone could help me. But let's talk about the problem. When I compile the project by myself everything seems to succeed but no way to reach the development board from the net. MAC configuration messages looks like the working case, "web server starting up" but development board is unreachable. Neither ping can get answers. Please, does anyone have a suggestion to me to fix this problem?! Thanks a lot guys. Regards, Massi.
