17 years agoStratix III Dev kit ethernet problem
I am using the Stratix III dev kit: http://www.altera.com/products/devkits/altera/kit-siii-host.html and I have programmed the board with the correct NIOS II standard design. I am able to run al...
15 years agoDoes anyone have a functional project for this board that is compatible with Nios II Linux or uClinux?
I just need one that has altera triple speed ethernet and run linux (uClinux or nios2 linux) correctly. If some of you could send me this project I would really appreciate. Thank you.
