17 years agoStratix III Dev kit ethernet problem
I am using the Stratix III dev kit: http://www.altera.com/products/devkits/altera/kit-siii-host.html and I have programmed the board with the correct NIOS II standard design. I am able to run al...
15 years agoDear All,
I'm back after a long time. Make the gigabit interface working succeded using the project posted in this thread. Connection is reliable, i can send and receive data. But Unfortunately I experienced a very low data transfer, more or less the same as the 100Mbps link. Negotiation on both side is at 1000. Does anyone has some suggestion to understand this, Am I wrong somewhere or is there some kind of bug that succeed in 1Gb negotiation but strongly limits the transfer rate? Please, help me to understand the problem. Thanks a Lot.
