NEEK Picture Viewer - Final Code will not run - Target Not Responding
When following the NEEK Picture Viewer I get the following error when trying to run on the target:-
Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused Story so far - followed demo all ok, get a message when programming device from Quartus II Programmer: Click Cancel to stop using OpenCore Plus IP Which you have to click Cancel as no other option. Above 'FAILED' message appears when Flash programming the Images.ZIP file and when tell NIOS IDE to run on the target hardware. I have no error messages during the complies of hw or sw. Using Following: WinXP SP2 Nios IDE 9.1 Build 222 Programmer 9.1 Build 222 Quartus II 9.1 Build 222 Demo PDF > http://www.altera.com/literature/tt/tt_nios2_system_architect.pdf Any help please. Thanks Paul PS: Hello_World demo build and runs ok...6 Replies
Don't click cancel as that will always cause this to happen. The Picture Viewer has some SD card IP that requires a license or OCP to use. Since you don't have a license, you'll need to leave this OCP window open.
If you want to rid yourself of this requirement, either purchase a license for the IP or write your own SD card hw/sw IP. Cheers, slacker - Altera_Forum
--- Quote Start --- Don't click cancel as that will always cause this to happen. The Picture Viewer has some SD card IP that requires a license or OCP to use. Since you don't have a license, you'll need to leave this OCP window open. If you want to rid yourself of this requirement, either purchase a license for the IP or write your own SD card hw/sw IP. Cheers, slacker --- Quote End --- I'm confused-!? The Tutorial says the Image.ZIP files need to be programmed into FLASH memory, I would have said this in not the SD card therefor? There is nothing in the tutorial about using the SD card so I'm guessing you are referring to the example that appears on the NEEK and in the example folder that installed. Can you confirm? Also would have expected a tutorial not to need a IP lic in order to evaluate the product. Thanks Paul - Altera_Forum
_something_ needs an IP license or you wouldn't be getting that message and you won't be able to run in standalone/untethered mode without resolving it.
Do you have a license for Nios II core? Though the "e" core does not require one, the others do. - Altera_Forum
The two Warning messages I'm getting are:
Reading the warning message box again when programming its says "Time Remaining - unlimited". So still confused by this.?Warning: "Nios II Processor (6AF7_00A2)" will use the OpenCore Plus Hardware Evaluation feature Warning: ""DDR High Performance Controller" (6AF7_00BE)" will use the OpenCore Plus Hardware Evaluation feature - Altera_Forum
Both of those pieces of IP require that you keep the OCP window open after programming..."tethered" mode...for evaluation purposes only. When cores use OCP, they query the host periodically to make sure it's still connected. Closing that window closes that connection.
You would need licenses for both the Nios II and the DDR controller in order to proceed with the design/tutorial as is. Regards, slacker - Altera_Forum
many thanks for your help - thats what I was doing, closing the box not understanding it.
I've been very impressed witht he kit and will be spending more time with it. I got it so that I could add a review to the DesignSpark website, here if your intrested -> link (http://www.designspark.com/product/nios-ii-evaluation-kit-cyclone-iii#comment-1633) Support from you guys on the Forum have been great in helping me along. Thanks again. Paul
