15 years agoNEEK Picture Viewer - Final Code will not run - Target Not Responding
When following the NEEK Picture Viewer I get the following error when trying to run on the target:- Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not respondi...
15 years agoThe two Warning messages I'm getting are:
Warning: "Nios II Processor (6AF7_00A2)" will use the OpenCore Plus Hardware Evaluation feature
Warning: ""DDR High Performance Controller" (6AF7_00BE)" will use the OpenCore Plus Hardware Evaluation feature
Reading the warning message box again when programming its says "Time Remaining - unlimited". So still confused by this.?
