15 years agoNEEK Picture Viewer - Final Code will not run - Target Not Responding
When following the NEEK Picture Viewer I get the following error when trying to run on the target:- Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not respondi...
15 years agoBoth of those pieces of IP require that you keep the OCP window open after programming..."tethered" mode...for evaluation purposes only. When cores use OCP, they query the host periodically to make sure it's still connected. Closing that window closes that connection.
You would need licenses for both the Nios II and the DDR controller in order to proceed with the design/tutorial as is. Regards, slacker
