15 years agoNEEK Picture Viewer - Final Code will not run - Target Not Responding
When following the NEEK Picture Viewer I get the following error when trying to run on the target:- Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not respondi...
15 years ago --- Quote Start --- Don't click cancel as that will always cause this to happen. The Picture Viewer has some SD card IP that requires a license or OCP to use. Since you don't have a license, you'll need to leave this OCP window open. If you want to rid yourself of this requirement, either purchase a license for the IP or write your own SD card hw/sw IP. Cheers, slacker --- Quote End --- I'm confused-!? The Tutorial says the Image.ZIP files need to be programmed into FLASH memory, I would have said this in not the SD card therefor? There is nothing in the tutorial about using the SD card so I'm guessing you are referring to the example that appears on the NEEK and in the example folder that installed. Can you confirm? Also would have expected a tutorial not to need a IP lic in order to evaluate the product. Thanks Paul
