15 years agoNEEK Picture Viewer - Final Code will not run - Target Not Responding
When following the NEEK Picture Viewer I get the following error when trying to run on the target:- Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not respondi...
15 years agoDon't click cancel as that will always cause this to happen. The Picture Viewer has some SD card IP that requires a license or OCP to use. Since you don't have a license, you'll need to leave this OCP window open.
If you want to rid yourself of this requirement, either purchase a license for the IP or write your own SD card hw/sw IP. Cheers, slacker
