15 years agoNEEK Picture Viewer - Final Code will not run - Target Not Responding
When following the NEEK Picture Viewer I get the following error when trying to run on the target:- Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not respondi...
15 years ago_something_ needs an IP license or you wouldn't be getting that message and you won't be able to run in standalone/untethered mode without resolving it.
Do you have a license for Nios II core? Though the "e" core does not require one, the others do.
