JTAG chain is broken when DDR4 is enable
I'm using ATTILA Arria10GX development kit with Quartus Prime 18.1.0 Build 222:
1, The JTAG works fine when my design system only has a NIOS II processor.
2, The JTAG chain will become broken once I have incorporated the DDR4 module into the system:
$ jtagconfig -d
1) Arria10 IDK [USB-1]
(JTAG Server Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition)
Unable to read device chain - Hardware not attached
Captured DR after reset = (02E660DD031020DD)
Captured IR after reset = ()
Captured Bypass after reset = (0)
Captured Bypass chain = ()
JTAG clock speed 6 MHz
Any ideas to solve this issue ?
Ke
- JohnT_Altera
Do you enable the JTAG debug for the DDR4 IP? Could you check your full design to see what IP does have the JTAG debug features enabled?
- KJian6
- KJian6
1, Yes, I do enable the JTAG debug for the DDR4 IP. (See above image for reference).
Another IP in the design which enable JTAG debug feature is NIOS processor. (see attached image for reference.)
2, The following are JTAG log messages:
$ jtagconfig -d
Captured DR after reset = (02E660DD)
$ jtagconfig --getparam 1 JtagClock
6M
$ jtagconfig --setparam 1 JtagClock 24M
No parameter named JtagClock
- JohnT_Altera
HI,
Could you check on your board to see if the DDR4 connection is interfering with your JTAG Chain connection? I suspect that there is some signal integrity on your JTAG Chain connection.
Could you try to disable the DDR4 IP's JTAG debugger? I don't think it will be any difference.
- KJian6
I have disabled the DDR4 IP's JTAG debugger as the attached picture, The JTAG chain is still broken:
$ jtagconfig -d
- JohnT_Altera
I suspect that either the DDR4 board interface or other IP that is physically crosstalk with the JTAG chain on your board which is causing the issue. I would recommend you to contact Reflexces company to check if the board have some issue or not.
- KJian6
HI,
1) I have contacted the Reflexces for Board issues and waiting for their update.
2) At the same time, I have another question about Quartus prime's report for this DDR4 project:
In PLL Usage summary report:
Only five PLLs are listed:
i_pll_sys|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst
eusb31dc_qsys|emif_0|emif_0|arch|arch_inst|pll_inst|pll_inst
eusb31dc_qsys|emif_0|emif_0|arch|arch_inst|pll_inst|pll_inst~_Duplicate
eusb31dc_qsys|emif_0|emif_0|arch|arch_inst|pll_inst|pll_inst~_Duplicate_1
eusb31dc_qsys|emif_0|emif_0|arch|arch_inst|pll_inst|pll_inst~_Duplicate_3
But in Fitter summary report, It reported there are 53 PLLs in the system:
Total RAM Blocks 161 / 2,713 ( 6 % )
Total DSP Blocks 2 / 1,518 ( < 1 % )
Total HSSI RX channels 0 / 48 ( 0 % )
Total HSSI TX channels 0 / 48 ( 0 % )
Total PLLs 53 / 112 ( 47 % )
Why did fitter summary report 53 PLLs in total instead of 5 PLLs?
Moreover, If I remove the DDR4 module from Qsys, Then the fitter summary will report only 1 PLL in total as we expect.
Any idea for the above issue ?
My software version is: Quartus Prime version 18.0 Build 222
- KJian6
Hi:
The DDR4 JTAG chain broken issue in Attila dev kit has been fixed with Reflexces company latest MAX 5 FPGA file (MV_Final.pof). Many thanks for your great help!
