KJian6
7 years agoJTAG chain is broken when DDR4 is enable
Hi, I'm using ATTILA Arria10GX development kit with Quartus Prime 18.1.0 Build 222: 1, The JTAG works fine when my design system only has a NIOS II processor. 2, The JTAG chain will become ...
JohnT_Altera
7 years agoHi,
I suspect that either the DDR4 board interface or other IP that is physically crosstalk with the JTAG chain on your board which is causing the issue. I would recommend you to contact Reflexces company to check if the board have some issue or not.
