binfu1's avatar
binfu1
1 year ago
FFT Intel FPGA IP
When I use FFT Intel FPGA IP (version 19.1), the simulation results of fft is correct (compared with python calculate results). Then I assert inverse signal to calculate ifft, the results is incorrect. Note that the configuration of the IP is as follows. Can you tell me why the error happens, and how to solve this problem, thanks.
  • CheepinC_altera's avatar
    CheepinC_altera
    Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
    CheepinC_altera
    I understand you’re experiencing unexpected results with the iFFT output from the Intel FPGA FFT IP. To help ensure we’re aligned and to assist you effectively, could you please share the following details:
    1. The specific FPGA device and Quartus version you’re using.
    2. A simple simulation setup in QuestaSim that replicates the issue, along with the detailed steps you followed.
    3. The expected (golden) results and a brief explanation of the discrepancy you’re observing.
    4. Just wonder if similar issue observed if you are using single direction iFFT.
    This information will help me better understand the context and investigate further.
    Please let me know if you have any concerns or need clarification. Thank you.
    Chee Pin
  • binfu1's avatar
    binfu1
    Thanks for your reply, the feedback of your requests are as follows:
    1.The FPGA device is Agilex7: AGIB027R29A1E2VR0, Quartus version is Quartus-pro-24.3.0.212.
    2.The simulator is vcsmx, following the standard simulation steps.
    3.First I simulate the forward FFT, the input data is shown as Fig.1, and the simulation result is shown as Fig.2. After digit-reverse, the result is shown as Fig.3. The calculation result of python is shown as Fig.4, and we can see the results of calculation and simulation are consistent. Then I simply assert the inverse signal of FFT Intel FPGA IP, the input data is same as before, the simulation result is shown as Fig.5 (after digit-reverse), and the calculation results of python is shown as Fig.6. we can see the results are inconsistent. I have tried the Variable Size FFT Intel FPGA IP for the same calculation, the result is shown in Fig.7 (after bit-reverse), and we can see the results are consistent. As a result, I confirm the calculation result of python is correct, and the simulation result of Intel FPGA FFT IP is wrong.
    4.I have tried set direction as reverse only, the results is same (wrong).
    Best regards
    CheepinC_altera
    Thanks for your update. Please feel free to correct me if any of the following understandings are inaccurate:
    1. Using the FFT Intel FPGA IP (version 19.1) in Bi-directional mode, asserting the invert input signal appears to result in an output sequence that does not match the expected Python-generated values.
    2. In Reverse mode with the same IP version, the output also seems to be incorrect.
    3. However, when using the Variable Size FFT Intel FPGA IP in Inverse VFFT mode, the output aligns correctly with the Python values.
    From what I understand, the FFT Intel FPGA IP (version 19.1) was previously primarily intended for legacy devices. Would it be feasible for you to use the Variable Size FFT Intel FPGA IP as a workaround?
    Please let me know if you have any concerns or need further clarification. Thank you.
    Chee Pin
    • binfu1's avatar
      binfu1
      Thanks for your reply. I need to change FFT mode (forward and inverse FFT) in the runtime, so the FFT Intel FPGA IP is my best choice. Although I can modify the Variable Size FFT Intel FPGA IP to realize the same function, I want to make sure the problem mentioned above caused by the IP itself, instead of improper use of mine.
      Best regards.
        CheepinC_altera
        Thanks for your clarification. I’ll continue investigating the behavior of the FFT IP v19.1 and will keep you updated on any findings.
        In the meantime, I understand that the Variable Size FFT Intel FPGA IP allows for a static configuration of Forward/Inverse mode during IP setup. Could you kindly elaborate on how you modified the IP to enable runtime switching between FFT modes?
        Appreciate your insights. Thank you.
        Chee Pin
    CheepinC_altera
    Just to keep you posted—I’ve conducted a series of tests using both FFT IP v19.1 and the Unified FFT IP. It appears that the output from FFT IP v19.1 in inverse FFT mode is not as expected. However, when using the Unified FFT IP in inverse FFT mode, the output behaves as expected.
    Based on this observation, as a workaround, you may proceed with your modification using the Variable Size FFT Intel FPGA IP. I’ll also share this feedback with Engineering for further investigation.
    Apologies for any inconvenience caused, and thank you for your understanding.
    Chee Pin
    • TKapi's avatar
      TKapi
      Dear Mr. Chee Pin,
      I use Max 10 and FFT IP (version 24.x and 25.1). FFT works good. But IFFT (Direction inverse) does not works - tt behaves as if the "inverse" was not set.
      Could this be the same problem?
      Unfortunately, I cannot use Unified FFT IP with Max 10.
      Thank you.
    CheepinC_altera
    Hi TKapi,
    Regarding your observation with the FFT IP, I suspect it may be similar to the issue seen with FFT IP v19.1. Since you’re unable to use the Unified FFT IP, you might want to consider the workaround mentioned in the previous note in this thread.
