FFT Intel FPGA IP
Just to keep you posted—I’ve conducted a series of tests using both FFT IP v19.1 and the Unified FFT IP. It appears that the output from FFT IP v19.1 in inverse FFT mode is not as expected. However, when using the Unified FFT IP in inverse FFT mode, the output behaves as expected.
Based on this observation, as a workaround, you may proceed with your modification using the Variable Size FFT Intel FPGA IP. I’ll also share this feedback with Engineering for further investigation.
Apologies for any inconvenience caused, and thank you for your understanding.
Chee Pin
Dear Mr. Chee Pin,
I use Max 10 and FFT IP (version 24.x and 25.1). FFT works good. But IFFT (Direction inverse) does not works - tt behaves as if the "inverse" was not set.
Could this be the same problem?
Unfortunately, I cannot use Unified FFT IP with Max 10.
Thank you.
