14 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ?
I see quite a bit of discussion here in a similar vein, but do not see anything conclusive. I see the USB is connected to an FTDI FT245BL - this should be capable of 1M Byte / Sec, using their D2XX Drivers. It is then connected to an Altera MAX chip. Previous fpga modules that I have used with FTDI chips have been able to use the USB port for both programming and for data transfer. Or am I better to junk the DE1 board and buy a DE2 which I see has a second USB port ? cheers, Beau54 Replies
Ah I see. I will try again tomorrow.
cheers for that, Beau - Altera_Forum
At last, progress with my Morohic II code.
As I thought, it was configuration/set-up that needed sorting. Went back to old fpgas where things worked, realised that at the end of the program up-load I was doing various reset and config things. Now with the Morphic II, I am using their program upload .dll, but still need to do the reset and config. Will try this with the USB Blaster tomorrow. - Altera_Forum
But no progress with the USB Baster.
I have added relevant bits of reset and config for the FTDI USB port, and I have tried both the bit and byte variants of the JTAG TAP machine reset. But still get toggling on TDI Pin 9, TMS Pin 5, with TCK and TDO low. I have confirmed that I can use the Quartus and the USB Blaster to load the Morphic II program - TCK toggles fine, showing a clock type signal, Quartus reports success, the green Init_Done light comes on, indicating programming is completed. However the program does not actually run, I assume something is holding it reset. - Altera_Forum
--- Quote Start --- However the program does not actually run, I assume something is holding it reset. --- Quote End --- The first thing you want to do, is create a design file that you know 'does something'. My usual preference is for 'blinky LEDs'. The Morph-IC board also uses an LED on the INIT_DONE line. However, rather than generating a design file that uses INIT_DONE, I use it as a general purpose I/O, and then blink the LED. Copy the body of the attached .vhd file into an entity that describes the Morphic-II pinout, and connect the INIT_DONE as shown in this design. Then go make the pin assignments, and download with the USB-Blaster. What does the Morphic-II use for the configuration interface from the FTDI2232? Is it using passive serial configuration like the Morph-IC, or is it using the JTAG pins? If its passive serial, then I can give you my Morph-IC programming code. Cheers, Dave - Altera_Forum
Sorry, I was not clear.
Yes I do use a LED, but had not thought of borrowing the Init_Done LED. I just have a connector on Con_1, with a couple of LEDS. One is fed from, as you say, a 1 sec toggle driven from counters, and is a nice clear indicator that the fpga is loaded and running. It loads and runs fine when loaded from the built-in Morphic USB connector via DS2232H pin B, using the FTDI DX call from AplX : FTStatus ← FT_ProgramMorphICDevice Hndl FileName I then wanted to test the USB Blaster was working, so tried loading the program that way. I used JTAG mode - would that be correct for this method ? It appears to load (Quartus reports OK, Init_Done LED goes on), but blinky LED stays off. Any thoughts ? - Altera_Forum
--- Quote Start --- It loads and runs fine when loaded from the built-in Morphic USB connector via DS2232H pin B, using the FTDI DX call from AplX : FTStatus ← FT_ProgramMorphICDevice Hndl FileName --- Quote End --- You mean 'port B'. Ok, so we know the FPGA works. --- Quote Start --- I then wanted to test the USB Blaster was working, so tried loading the program that way. I used JTAG mode - would that be correct for this method ? It appears to load (Quartus reports OK, Init_Done LED goes on), but blinky LED stays off. Any thoughts ? --- Quote End --- So you've got a USB-Blaster connected to the JTAG header on the Morph-IC-II board? And you know the USB-Blaster works? Do you have the Morph-IC-II schematic? Can you probe the CONF_DONE, nSTATUS, CONFIGn, etc pins? Actually, if the FT2232 is using passive serial mode, then you can read the state of those pins via the Morph-IC-II Port B interface (since the programming interface needs to access these signals). If CONF_DONE is not high after you load the FPGA via the USB-Blaster, then it indicates a problem with the JTAG interface. Cheers, Dave - Altera_Forum
--- Quote Start --- I assume something is holding it reset. --- Quote End --- You can test this theory by *not* using a reset signal in your design, eg., if there is a port called ext_rstN that you are using like rstN <= ext_rstN, just change it to rstN <= '1'; And if your design works, then you know the external reset is staying asserted. If you look at the Morph-IC-II schematic, the reset signal is likely coming from a FT2232 GPIO, and when you load via USB-Blaster, you do not deassert that pin, so you'll need to write a program to assert/deassert the reset GPIO. Cheers, Dave - Altera_Forum
Well, opening the FT2232H B port seems to start the program running :
(LED dim) Program the fpga via the ,HandleB ← ft_OpenSpecifiedMorphICDevice Name1 Sn1 40974824 HandleB ft_ProgramMorphICDevice File (LED toggling, INIT_DONE lit) , Tmp_Prg ← ftgetbitmode HandleB 0 0 0 1 1 1 1 0 ft_CloseMorphICDevice HandleB (unplug USB lead from FT2232H to remove power and ensure program is wiped, re-plug) (LED dim) (program fpga via USB Blaster - reports success) (LED off, INIT_DONE lit) ,HandleB ← ft_OpenSpecifiedMorphICDevice Name1 Sn1 40974824 (LED toggling, INIT_DONE lit) , Tmp_UB ← ftgetbitmode HandleB 0 0 0 1 1 1 1 0 So I guess the USB Blaster is working fine. - Altera_Forum
--- Quote Start --- Well, opening the FT2232H B port seems to start the program running --- Quote End --- Are you using a reset signal in your design? Does the reset come from the FT2232? Do the bit values you show correspond to the deassertion of the reset signal - hence explaining why your configuration starts to work? Cheers, Dave - Altera_Forum
Reset :
Yes, the design uses a reset : HW_RESET, but the connection takes some tracing : HW_RESET, fpga pin B3 - this is labled Data3 There is an external reset : Resetin#, connector J1-14 - this goes to the FT2232H pin 14, with a pull up resistor. The crucial commection for the reset is from the FT2232H pin 46 : BDBUS7, again labled Data3. I have tried setting and clearing the top bit of the FT2232H B bus, to see if I can halt the operation but not sure I am doing it right yet. Will go read the data sheet again.
