15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years agoReset :
Yes, the design uses a reset : HW_RESET, but the connection takes some tracing : HW_RESET, fpga pin B3 - this is labled Data3 There is an external reset : Resetin#, connector J1-14 - this goes to the FT2232H pin 14, with a pull up resistor. The crucial commection for the reset is from the FT2232H pin 46 : BDBUS7, again labled Data3. I have tried setting and clearing the top bit of the FT2232H B bus, to see if I can halt the operation but not sure I am doing it right yet. Will go read the data sheet again.
