15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years agoBut no progress with the USB Baster.
I have added relevant bits of reset and config for the FTDI USB port, and I have tried both the bit and byte variants of the JTAG TAP machine reset. But still get toggling on TDI Pin 9, TMS Pin 5, with TCK and TDO low. I have confirmed that I can use the Quartus and the USB Blaster to load the Morphic II program - TCK toggles fine, showing a clock type signal, Quartus reports success, the green Init_Done light comes on, indicating programming is completed. However the program does not actually run, I assume something is holding it reset.
