15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- Well, opening the FT2232H B port seems to start the program running --- Quote End --- Are you using a reset signal in your design? Does the reset come from the FT2232? Do the bit values you show correspond to the deassertion of the reset signal - hence explaining why your configuration starts to work? Cheers, Dave
