15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years agoWell, opening the FT2232H B port seems to start the program running :
(LED dim) Program the fpga via the ,HandleB ← ft_OpenSpecifiedMorphICDevice Name1 Sn1 40974824 HandleB ft_ProgramMorphICDevice File (LED toggling, INIT_DONE lit) , Tmp_Prg ← ftgetbitmode HandleB 0 0 0 1 1 1 1 0 ft_CloseMorphICDevice HandleB (unplug USB lead from FT2232H to remove power and ensure program is wiped, re-plug) (LED dim) (program fpga via USB Blaster - reports success) (LED off, INIT_DONE lit) ,HandleB ← ft_OpenSpecifiedMorphICDevice Name1 Sn1 40974824 (LED toggling, INIT_DONE lit) , Tmp_UB ← ftgetbitmode HandleB 0 0 0 1 1 1 1 0 So I guess the USB Blaster is working fine.
