15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years agoSorry, I was not clear.
Yes I do use a LED, but had not thought of borrowing the Init_Done LED. I just have a connector on Con_1, with a couple of LEDS. One is fed from, as you say, a 1 sec toggle driven from counters, and is a nice clear indicator that the fpga is loaded and running. It loads and runs fine when loaded from the built-in Morphic USB connector via DS2232H pin B, using the FTDI DX call from AplX : FTStatus ← FT_ProgramMorphICDevice Hndl FileName I then wanted to test the USB Blaster was working, so tried loading the program that way. I used JTAG mode - would that be correct for this method ? It appears to load (Quartus reports OK, Init_Done LED goes on), but blinky LED stays off. Any thoughts ?
