14 years ago
Ethernet Example Design on Cyclone III Dev Board (3C120F780)
I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO:   0x12 141 cc2
PHY INFO:  Issuing PHY Reset
PHY INFO:  waiting on PHY link...
PHY INFO:  PHY link detected, allowing network to start.
SSS INFO:  Connecting...
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:08:xx:xx
prepped 1 interface, initializing...
INFO    : TSE MAC 0 found at address 0x0800a000
INFO    : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group
INFO    : PHY - Automatically mapped to tse_mac_device
INFO    : PHY - Restart Auto-Negotiation, checking PHY link...
INFO    : PHY - Auto-Negotiation PASSED
INFO    : PHY - Checking link...
INFO    : PHY - Link established
INFO    : PHY - Speed = 1000, Duplex = Full
OK, x=48, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
 RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 134.130.xxx.xxx
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Nios II Simple Socket Server starting up.
Created "monitor_phy" task (Prio: 9)
Created "Nios II Simple Socket Server" task (Prio: 10)
 Nios II Simple Socket Server listening on port 30
The DHCP isn't working, I cannot ping the board and telnet isn't working.
In a next step I set the IP to a static one -> the same effect.
I got the same effect for the example templates in Nios2-Eclipse.
I checked the same design with the NEEK board and it runs well (naturally the .sof for the NEEK) with the original flash-file (the application selector) and the niosii_ethernet_standard_3c25.sof overloading.
Using another flash-content, it also doesn't work like the 3C120.
Any idea?
Best Regards
Mark
    IIRC there is something special to do to set up the interface in rgmii mode, as it is on the 3C120 kit. I don't remember it exactly but a search on the forum could help.
    Looking in the software templates in Quartus 10.1 they seem to have created special rgmii templates, maybe you can try those.
    I tried out the SimpleSocketServer_RGMII and this one is running. It seems so, that the 3C120 Dev Board needs a RGMII-Design in Nios.
    Thanks a lot to Daixiwen! You gave me the special tip.
    Possibly Altera adds the RGMII code to the 3c120-board tuturial.
    Best Regards
    Mark
    This a all things you need, If it help for you. Thanks to me so much
    I done
    error_t generate_mac_addr(unsigned char mac_addr[6])
    error_t error = -1;
    alt_u32 ser_num = 0;
    printf("\nCan't read the MAC address from your board. We will assign you\n");
    printf("a MAC address.\n\n");
    ser_num = get_serial_number();
    if (ser_num)
    /* This is the Altera Vendor ID */
    mac_addr[0] = 0x0;
    mac_addr[1] = 0x7;
    mac_addr[2] = 0xed;
    /* Reserverd Board identifier */
    mac_addr[3] = 0xFF;
    mac_addr[4] = (ser_num & 0xff00) >> 8;
    mac_addr[5] = ser_num & 0xff;
    printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n",
    mac_addr[0],
    mac_addr[1],
    mac_addr[2],
    mac_addr[3],
    mac_addr[4],
    mac_addr[5]);
    error = 0;
    return error;
    * get_board_mac_addr
    * Read the MAC address in a board specific way
    error_t get_board_mac_addr(unsigned char mac_addr[6])
    error_t error = 0;
    alt_u32 signature;
    if (!error)
    signature = IORD_32DIRECT(last_flash_sector, 0);
    if (signature != 0x00005afe)
    error = generate_and_store_mac_addr();
    if (!error)
    mac_addr[0] = IORD_8DIRECT(last_flash_sector, 4);
    mac_addr[1] = IORD_8DIRECT(last_flash_sector, 5);
    mac_addr[2] = IORD_8DIRECT(last_flash_sector, 6);
    mac_addr[3] = IORD_8DIRECT(last_flash_sector, 7);
    mac_addr[4] = IORD_8DIRECT(last_flash_sector, 8);
    mac_addr[5] = IORD_8DIRECT(last_flash_sector, 9);
    mac_addr[0],
    mac_addr[1],
    mac_addr[2],
    mac_addr[3],
    mac_addr[4],
    mac_addr[5]);
    return error;
    * get_mac_addr
    int get_mac_addr(NET net, unsigned char mac_addr[6])
    error_t error = 0;
    error = get_board_mac_addr(mac_addr);
    if(error)
    /* Failed read MAC address from flash, prompt user to enter serial
    number to generate MAC address. */
    error = generate_mac_addr(mac_addr);
    return error;
    * get_ip_addr()
    * This routine is called by InterNiche to obtain an IP address for the
    * specified network adapter. Like the MAC address, obtaining an IP address is
    * very system-dependant and therefore this function is exported for the
    * developer to control.
    * In our system, we are either attempting DHCP auto-negotiation of IP address,
    * or we are setting our own static IP, Gateway, and Subnet Mask addresses our
    * self. This routine is where that happens.
    int get_ip_addr(alt_iniche_dev *p_dev,
    ip_addr* ipaddr,
    ip_addr* netmask,
    ip_addr* gw,
    int* use_dhcp)
    IP4_ADDR(*ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3);
    IP4_ADDR(*gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3);
    IP4_ADDR(*netmask, MSKADDR0, MSKADDR1, MSKADDR2, MSKADDR3);
    # ifdef DHCP_CLIENT
    *use_dhcp = 1;
    # else /* not DHCP_CLIENT */
    *use_dhcp = 0;
    printf("Static IP Address is %d.%d.%d.%d\n",
    ip4_addr1(*ipaddr),
    ip4_addr2(*ipaddr),
    ip4_addr3(*ipaddr),
    ip4_addr4(*ipaddr));
    # endif /* not DHCP_CLIENT */
    /* Non-standard API: return 1 for success */
    return 1;
    * Flash service functions.
    # include "sys/alt_flash.h"
    # include "sys/alt_flash_dev.h"
    * FindLastFlashSectorOffset
    * <-- pLastFlashSectorOffset Offset of last sector in flash.
    * This function finds the offset to the last sector in flash and returns it
    * in pLastFlashSectorOffset.
    int FindLastFlashSectorOffset(
    alt_u32 *pLastFlashSectorOffset)
    alt_flash_fd *fd;
    flash_region *regions;
    int numRegions;
    flash_region *pLastRegion;
    int lastFlashSectorOffset;
    int n;
    int error = 0;
    /* Open the flash device. */
    fd = alt_flash_open_dev(EXT_FLASH_NAME);
    if (fd <= 0)
    error = -1;
    /* Get the flash info. */
    if (!error)
    error = alt_get_flash_info(fd, &regions, &numRegions);
    /* Find the last flash sector. */
    if (!error)
    pLastRegion = &(regions[0]);
    for (n = 1; n < numRegions; n++)
    if (regions[n].offset > pLastRegion->offset)
    pLastRegion = &(regions[n]);
    lastFlashSectorOffset = pLastRegion->offset
    + pLastRegion->region_size
    - pLastRegion->block_size;
    /* Return results. */
    if (!error)
    *pLastFlashSectorOffset = lastFlashSectorOffset;
    return (error);
    in addition, You can post up a code that you defined your IP to ping. and I can test helping for you. I'm also related to my topic.
    Above all, You should test define in "simple_socket_server.h"
    there a numerous at "web_server.h"
    in addition, I think that define for IP address have a problem.
    please posted full code it will show how code error.
    Hi all,
    i got a NEEK 3c25 board, i've followed instructions step by step but at the end when i launch Eclipse project the console output get stuck with:
    and nothing happens, no IP is assigned to the board and lights on Ethernet connector of the NEEK board remains on with no blinking.
    If i attach/detach ethernet plug to NEEK board it's the same..
    My configuration is PC LAN with DHCP and NEEK LAN connected to a switch.
    I've tried also to uncheck dhcp in BSD properties but this action lead to impossility to compile eclipse project i have a lot of errors...
    Hi Mark,
    May be this thread is too old. But I am also stuck with the same problem now. I have a relatively old Cyclone III FPGA board, bought in 2009 I think. It could not run the "simple_socket_server_rgmii" example provided in "altera\12.1\nios2eds\examples\software". It cannot run even the recently downloaded example from: http://www.altera.com/support/examples/nios2/exm-using-nichestack.html . I added -DTSE_MY_SYSTEM flag and also commented out "IOWR(&pmac->mdio1.reg14, 0, dat); " line as suggested here: http://www.niosii.com/support/kdb/solutions/rd01042012_567.html
    The "tse_my_system.c" file is already provided in the recent example with the necessary code. Do you have any idea what might have gone wrong? Do I need to change any settings on my computer?
