14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
14 years agoAbove all, You should test define in "simple_socket_server.h"
there a numerous at "web_server.h" in addition, I think that define for IP address have a problem. please posted full code it will show how code error.
