14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
14 years agoThis a all things you need, If it help for you. Thanks to me so much
I done
