14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
14 years agoHi,
I tried out the SimpleSocketServer_RGMII and this one is running. It seems so, that the 3C120 Dev Board needs a RGMII-Design in Nios. Thanks a lot to Daixiwen! You gave me the special tip. Possibly Altera adds the RGMII code to the 3c120-board tuturial. Best Regards Mark
