14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
12 years agoHi all,
i got a NEEK 3c25 board, i've followed instructions step by step but at the end when i launch Eclipse project the console output get stuck with: PHY INFO: waiting on PHY link... and nothing happens, no IP is assigned to the board and lights on Ethernet connector of the NEEK board remains on with no blinking. If i attach/detach ethernet plug to NEEK board it's the same.. My configuration is PC LAN with DHCP and NEEK LAN connected to a switch. I've tried also to uncheck dhcp in BSD properties but this action lead to impossility to compile eclipse project i have a lot of errors...
