14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
12 years agoHi Mark,
May be this thread is too old. But I am also stuck with the same problem now. I have a relatively old Cyclone III FPGA board, bought in 2009 I think. It could not run the "simple_socket_server_rgmii" example provided in "altera\12.1\nios2eds\examples\software". It cannot run even the recently downloaded example from: http://www.altera.com/support/examples/nios2/exm-using-nichestack.html . I added -DTSE_MY_SYSTEM flag and also commented out "IOWR(&pmac->mdio1.reg14, 0, dat); " line as suggested here: http://www.niosii.com/support/kdb/solutions/rd01042012_567.html The "tse_my_system.c" file is already provided in the recent example with the necessary code. Do you have any idea what might have gone wrong? Do I need to change any settings on my computer? Thanks,
