cyclone 10GX DDR3 (not DDR3L) fitter plan error "Error(20403): Global setting for OUTPUT_IO_TIMING_N
Cyclone 10GX EV board example design of DDR3x40 on Quartus pro 20.4
After IP upgrade (also without upgrade ). The following error occurs at the fitter plan stage:
"Error(20403): Global setting for OUTPUT_IO_TIMING_NEAR_END_VMEAS is not supported. Please use this setting with pin assignments."
On quartus 20.4 error message web page there is no reference to that number.
https://www.intel.com/content/www/us/en/programmable/quartushelp/20.4/index.htm#msgs/msgs/msgs.htm
On quartus 17.1 (origin of that core) there is no problem.
But cant use it because lacking of Ethernet stuff.
Please advice
Not a big issue. But when I did upgrade the IP, some lines in the QSF file were marked as obsolete by quartus .
The unsupported setting of "OUTPUT_IO_TIMING_NEAR/FAR......." was not commented as expected.
I did it manually as suggested in the first replay by sstrell.
- sstrell
That sounds like a board trace model assignment. Check your .qsf file and any board trace model assignments in the Pin Planner.
- Yoram
done succefully.
Quartus 20.4 comment some irrelevant assignments when upgrade from previous IP versions but fail to comment the following:
- AdzimZM_Altera
Hi Yoram,
Do you still got the error message
"Error(20403): Global setting for OUTPUT_IO_TIMING_NEAR_END_VMEAS is not supported. Please use this setting with pin assignments." ?
What do you mean by your last feedback?
Can you elaborated it?
Adzim
- AdzimZM_Altera
Hi Yoram,
So now your problem has been fixed?
Adzim
- Yoram
problem solved
- AdzimZM_Altera
Hi Yoram,
Thanks to confirm about that.
I will close this case.
You can always file a new case in this forum if you got any problem.
Adzim
