Yoram
5 years agocyclone 10GX DDR3 (not DDR3L) fitter plan error "Error(20403): Global setting for OUTPUT_IO_TIMING_N
Cyclone 10GX EV board example design of DDR3x40 on Quartus pro 20.4
After IP upgrade (also without upgrade ). The following error occurs at the fitter plan stage:
"Error(20403): Global setting fo...
AdzimZM_Altera
5 years agoHi Yoram,
Do you still got the error message
"Error(20403): Global setting for OUTPUT_IO_TIMING_NEAR_END_VMEAS is not supported. Please use this setting with pin assignments." ?
What do you mean by your last feedback?
Quartus 20.4 comment some irrelevant assignments when upgrade from previous IP versions but fail to comment the following:
"OUTPUT_IO_TIMING_NEAR/FAR......."
Can you elaborated it?
Adzim
