Yoram
5 years agocyclone 10GX DDR3 (not DDR3L) fitter plan error "Error(20403): Global setting for OUTPUT_IO_TIMING_N
Cyclone 10GX EV board example design of DDR3x40 on Quartus pro 20.4
After IP upgrade (also without upgrade ). The following error occurs at the fitter plan stage:
"Error(20403): Global setting fo...
sstrell
5 years agoThat sounds like a board trace model assignment. Check your .qsf file and any board trace model assignments in the Pin Planner.
