Vivek_tiwari's avatar
Vivek_tiwari
5 years ago
Configuration Error in Stratix 10 After programming .jic file
I Tried programming Stratix 10 FPGA kit with .jic file using jtag msel pins as MSEL[2:0] as 111 and it was programmed successfully configuration error led D3 was still glowing red after that i power cycle the board and changes MSEL for 011 (AS Normal) and also tried 001 (AS FAST) but that config error led always glowing RED and its not Configuring at all
I want to program S10 through FLASH so even After power cycle i dont have to program again
I dont have any problem to program .sof then config_done led is glowing green
