Vivek_tiwari
5 years agoConfiguration Error in Stratix 10 After programming .jic file
I Tried programming Stratix 10 FPGA kit with .jic file using jtag msel pins as MSEL[2:0] as 111 and it was programmed successfully configuration error led D3 was still glowing red after that i power ...
JohnT_Altera
5 years agoHi,
Could you try to change the MSEL for 011 (AS Normal) and try to programmed the jic file? May I know how do you convert the jic file if you are still facing issue?
Could you try to follow the guide in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-config.pdf Chapter 7.4.1 and see what is the configuration status after you power cycle the board?
Vivek_tiwari
5 years agoHi John,
I tried with MSEL for 011(AS Normal) and there is no change in result.
I am converting file through (Convert Programming Files) tool and tried (Programming File generator ) as well.
I am attaching some screenshots for your reference .
Vivek
