okramer's avatar
okramer
6 years ago
Arria 10 GX dev kit board doesn't display anything on LCD after power up and doesn't connect to host via USB.
In an effort to debug other issues, I removed my new dev board from the host's PCIe and am using the DC power cable instead. When I switch power on, the LCD is backlit but blank. I used to see messages when plugged into PCIe. Now there's nothing. All the User LEDs are red, they used to be green. I have all DIP SW settings to defaults in section 3 of the User Guide.
When I run arria-10-dev-kit/examples/board_test_system/BoardTestSystem.sh, I get the UI with the message in the UI window saying, "No USB Blaster is detected or selected. Please check connections and restart the program."
On the host, jtagconfig shows:
$ jtagconfig
1) USB-BlasterII [1-6.2]
  02E660DD   10AX115H1(.|E2|ES)/10AX115H2/..
  020A40DD   5M(1270ZF324|2210Z)/EPM2210
Clearly the board is powering up in some weird state. I verified the DIP Switches SW3, SW4, SW5, and SW6 are set to the factory reset defaults.
However, when I set DIP SW6 pin 4 to "OFF" (factory reset disabled), the board comes up OK with all LEDs green and the LCD showing "Net Initialize..." (I don't have the ethernet cable plugged in).
With the USB cable connected, I run BoardTestSystem on the host but get an exception with a popup warning saying, "Failed to get this device." Here's the host's console output:
$ ./bts.sh
Success!
Current OS:Linux
Nov 07, 2019 11:06:07 AM com.altera.bts.BtsView <init>
INFO: Board version: Rev E3, chip version: PRD
Nov 07, 2019 11:06:07 AM com.altera.bts.systemconsole.client.ClientApp attachServer
INFO: [/home/okramer/intelFPGA_pro/19.3/quartus/sopc_builder/bin/system-console, --server]
INFO: Here is the standard output of the command:
Nov 07, 2019 11:06:11 AM com.altera.bts.systemconsole.client.ClientApp attachServer
INFO: TCP PORT: 46573
Nov 07, 2019 11:06:17 AM com.altera.bts.systemconsole.client.JtagInfo retrieveDeviceList
INFO: 2 device detected: /devices/10AX115H1(.|E2|ES)|10AX115H2|..@1#1-6.2 /devices/5M(1270ZF324|2210Z)|EPM2210@2#1-6.2
Nov 07, 2019 11:06:17 AM com.altera.bts.systemconsole.client.ClientApp getCompatibleBoardInfoArray
INFO: System Max matched: true, Fpga matched: true
Nov 07, 2019 11:06:17 AM com.altera.bts.BtsView <init>
INFO: Selected JTAG cable is: USB-BlasterII on localhost (1-6.2)
INFO: FPGA device on index 1, System MAX on index 2
Nov 07, 2019 11:06:17 AM com.altera.bts.InstanceChecker registerInstance
INFO: Application Register. Type: Board Test System GUI
Nov 07, 2019 11:06:17 AM com.altera.bts.systemconsole.client.SysConService <init>
INFO: Claim master service succeed! Service path: "/devices/5M(1270ZF324|2210Z)|EPM2210@2#1-6.2/(link)/JTAG/(110:130 v3 #0)/jtagmem_0", claimed path: /channels/remote1/(lib)/master_1.
Nov 07, 2019 11:06:18 AM com.altera.bts.SysInfo init
INFO: Claim sysinfo master service.
Nov 07, 2019 11:06:18 AM com.altera.bts.systemconsole.client.SysConService <init>
INFO: Claim master service succeed! Service path: "/devices/5M(1270ZF324|2210Z)|EPM2210@2#1-6.2/(link)/JTAG/(110:130 v3 #0)/jtagmem_0", claimed path: /channels/remote1/(lib)/master_2.
Nov 07, 2019 11:06:18 AM com.altera.bts.DesignDetection readFpgaDesignType
INFO: Claim FPGA master service to read design type.
SEVERE: java.io.IOException: Get master service paths failed! Device: "/devices/10AX115H1(.|E2|ES)|10AX115H2|..@1#1-6.2" Type:
INFO: Claim master service succeed! Service path: "/devices/10AX115H1(.|E2|ES)|10AX115H2|..@1#1-6.2/(link)/JTAG/(70:34 v3 #0)/nios2_0", claimed path: /channels/remote1/(lib)/master_3.
Nov 07, 2019 11:06:18 AM com.altera.bts.systemconsole.client.SysConService closeService
INFO: close_service master "/channels/remote1/(lib)/master_3"
Nov 07, 2019 11:06:18 AM com.altera.bts.Programmer getMessage
SEVERE: null
java.util.concurrent.ExecutionException: java.lang.NumberFormatException: For input string: "USB-BlasterII on localhost (1-6.2)"
	at java.util.concurrent.FutureTask.report(FutureTask.java:122)
	at java.util.concurrent.FutureTask.get(FutureTask.java:206)
	at com.altera.bts.Programmer.getMessage(Programmer.java:208)
	at com.altera.bts.BUP.updateBup(BUP.java:80)
	at com.altera.bts.BUP.access$100(BUP.java:44)
	at com.altera.bts.BUP$1BupTask.run(BUP.java:64)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
 	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
 	at java.lang.Thread.run(Thread.java:748)
 Caused by: java.lang.NumberFormatException: For input string: "USB-BlasterII on localhost (1-6.2)"
 	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
 	at java.lang.Integer.parseInt(Integer.java:580)
 	at java.lang.Integer.valueOf(Integer.java:740)
 	at java.lang.Integer.decode(Integer.java:1197)
 	at com.altera.bts.systemconsole.client.CommandShell.getUsbIndex(CommandShell.java:102)
 	at com.altera.bts.systemconsole.client.CommandShell.getUsbIndexString(CommandShell.java:109)
 	at com.altera.bts.systemconsole.client.CommandShell.getCableIndex(CommandShell.java:117)
 	at com.altera.bts.Programmer.lambda$getBoardInfo$0(Programmer.java:110)
 	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
 	... 3 more
Is there something I'm missing?
  • AR_A_Intel's avatar
    AR_A_Intel
    Hi
    May I know, have you tried BTS test with Quartus II software v15.1.2 build 193. You can check the requirement in readme.txt file. The manufactured board’s BTS was built with Quartus II software v15.1.2 build 193. Possibly it is caused by the difference in system console of different Quartus revisions. It is suggested to use the right Quartus version with the right dev.kit version.
  • okramer's avatar
    okramer
    @AAbd RAhman_Intel​ I tried with Quartus 19.3 and later with 18.1 after a suggestion from another Intel engineer. What readme.txt are you referring to? -- there are many. How can I tell what the dev kit version is? FWIW the board serial number is 10APCIe0003031.
  • okramer's avatar
    okramer
    ​@AAbd RAhman_Intel​ Thanks. That link contains the board package I previously downloaded, and that contains the BTS. I do see
     ACDS Release:  v15.1.2 build 193
     Board revision: Rev E3p1
    Software Requirements
    Demo applications installed with the Development Kit require the installation
    of Quartus Prime v15.1.2 or later and are supported on the following operating systems:
    That says "Quartus Prime v15.1.2 or later." But you say that Quartus needs to be exactly the same version? If so, then even though Quartus is at 19.3, the latest dev board package requires a much older Quartus? I couldn't find a download for Quartus 15.1.2, only 15.0.
    I moved my testing to an Ubuntu 16.04 box, USB only (no PCIe, but connecting via USB) and I still encounter the same error in BTS. Here is a screenshot with console in the background showing a java exception. Note bup_webserver.sof is loaded (I didn't do that). The device has ethernet connected and is indicating an address I reserved, but it is different than the .1.100 indicated on the GUI. Anything I try from the Configure menu generates the "failed to get device" warning.
  • okramer's avatar
    okramer
    I'm a bit skeptical about this. Even though the readme says, "Quartus Prime v15.1.2 or later," you say it has to be exactly 15.1.2, correct? To reinforce my skeptibility, I'm getting this message when downloading the older version:
    "Quartus Prime Pro Edition version 15.1 Beta is discontinued. Contact your Altera Sales representative."
