okramer
6 years agoArria 10 GX dev kit board doesn't display anything on LCD after power up and doesn't connect to host via USB.
In an effort to debug other issues, I removed my new dev board from the host's PCIe and am using the DC power cable instead. When I switch power on, the LCD is backlit but blank. I used to see messag...
AR_A_Intel
6 years agoSome of the IP file directory structures and hierarchy are different between Quartus version which could be contributing to the issue you have observed. Hence, that is the reason I requested to try installing Quartus Prime Standard 15.1.2 as the BTS UI that has been tested by the board manufacture.
Could you try download form this link https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
