Arria 10 GX dev kit board doesn't display anything on LCD after power up and doesn't connect to host via USB.
@AAbd RAhman_Intel Thanks. That link contains the board package I previously downloaded, and that contains the BTS. I do see
ACDS Release: v15.1.2 build 193
Board revision: Rev E3p1
Software Requirements
Demo applications installed with the Development Kit require the installation
of Quartus Prime v15.1.2 or later and are supported on the following operating systems:
That says "Quartus Prime v15.1.2 or later." But you say that Quartus needs to be exactly the same version? If so, then even though Quartus is at 19.3, the latest dev board package requires a much older Quartus? I couldn't find a download for Quartus 15.1.2, only 15.0.
I moved my testing to an Ubuntu 16.04 box, USB only (no PCIe, but connecting via USB) and I still encounter the same error in BTS. Here is a screenshot with console in the background showing a java exception. Note bup_webserver.sof is loaded (I didn't do that). The device has ethernet connected and is indicating an address I reserved, but it is different than the .1.100 indicated on the GUI. Anything I try from the Configure menu generates the "failed to get device" warning.
