tetto@ubuntuoffice:~$ aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
/etc/OpenCL/vendors
Found 3 icd entry at that location:
/etc/OpenCL/vendors/Altera.icd
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
/etc/OpenCL/vendors/intel64.icd
The following OpenCL libraries are referenced in the icd files:
/opt/intel/oneapi/compiler/latest/opt/oclfpga/host/linux64/lib/libalteracl.so
Checking LD_LIBRARY_PATH for registered libraries:
/opt/intel/oneapi/compiler/latest/opt/oclfpga/host/linux64/lib/libalteracl.so was registered on the system.
/opt/intel/oneapi/compiler/latest/lib/libintelocl_emu.so
/opt/intel/oneapi/compiler/latest/lib/libintelocl_emu.so was registered on the system.
/opt/intel/oneapi/compiler/latest/lib/libintelocl.so
/opt/intel/oneapi/compiler/latest/lib/libintelocl.so was registered on the system.
Using OCL_ICD_FILENAMES to search for ICD clients, it is set to libintelocl_emu.so:libalteracl.so:/opt/intel/oneapi/compiler/2024.0/lib/libintelocl.so
Checking LD_LIBRARY_PATH for registered libraries specified by OCL_ICD_FILENAMES
libintelocl_emu.so was registered on the system at /opt/intel/oneapi/compiler/2024.0/lib
libalteracl.so was registered on the system at /opt/intel/oneapi/compiler/2024.0/opt/oclfpga/host/linux64/lib
/opt/intel/oneapi/compiler/2024.0/lib/libintelocl.so was registered on the system.
Using the following location for fcd installations:
/opt/Intel/OpenCLFPGA/oneAPI/Boards
ERROR: No FCD entry at that location. Without ICD and FCD, host executables
must be linked directly to Intel FPGA runtime (libalteracl.so) and BSP MMD
library instead of to the Khronos ICD library (libOpenCL.so).
To use FCD, please reinstall using 'aocl install'.
ICD diagnostics FAILED
BSP Diagnostics
/opt/intel/oneapi/compiler/2024.0/opt/oclfpga/board/intel_a10gx_pac/linux64/libexec/diagnose: error while loading shared libraries: libopae-c.so.1: cannot open shared object file: No such file or directory
Warning:
No devices attached for package:
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
