oneAPI on Cyclone10gx
Hi @StefanoC,
Thank you for posting in Intel community forum on your interest in oneAPI and hope all is well.
If I understand the situation correctly it seems that you are trying to run the hardware compilation in the IP authoring flow, and based on the error message it complaining that device not found.
Hence suspecting that the command line used might be incorrect, for that you may refer to the compilation flags below:
Hope that clarify
Best Wishes
BB
- StefanoC2 years ago
I was following this:
and indeed I can compile with make (both emulation and fpga), the issue I experience is at runtime, when I try to execute the ./simple-add-buffers.fpga (previously I had issued cmake .. -DFPGA_DEVICE=cyclone10gx to really target my device).
Overall, I have a dual boot computer with windows10/ubuntu, on windows10 I was able to compile and download a sample vhdl to the fpga, so I am sure the board is powered ok/jtag cable is ok too, I am wondering if on ubuntu any additional driver/os related has to be installed. At the moment I have quartus prime (licence is ok) and oneAPI (on both windows10 and ubuntu). I would prefer Linux as I am more comfortable with command line, but I think I am missing something how to get the Cyclone 10gx board properly installed (my understanding was Quartus prime pro contains the cyclone10 driver..), what should I check to make sure my fpga is configured properly on my linux system?
thanks!
I am trying to compile and run this sample code:
#include <CL/sycl.hpp> #include <iostream> #include <sycl/ext/intel/fpga_extensions.hpp> using namespace cl::sycl; int main() { auto selector = sycl::ext::intel::fpga_selector_v; queue q(selector); const int N = 100; int a[N], b[N], c[N]; // Initialize arrays on the host for (int i = 0; i < N; i++) { a[i] = i; b[i] = i * 2; } buffer<int, 1> buf_a(a, range<1>(N)); // Create buffers for arrays buffer<int, 1> buf_b(b, range<1>(N)); buffer<int, 1> buf_c(c, range<1>(N)); q.submit([&](handler& h) { auto a_acc = buf_a.get_access<access::mode::read>(h); auto b_acc = buf_b.get_access<access::mode::read>(h); auto c_acc = buf_c.get_access<access::mode::write>(h); h.parallel_for(range<1>(N), [=](id<1> i) { c_acc[i] = a_acc[i] + b_acc[i]; // Perform element-wise addition }); }); q.wait(); // Wait for completion // Print results on the host for (int i = 0; i < N; i++) { std::cout << c[i] << " "; } std::cout << std::endl; return 0; }following your link/suggestion I did add the proper flags (see below), I also made sure the board is seen by the OS but I still get the following runtime error:
tetto@ubuntuoffice:~/mytrial1$ jtagconfig 1) USB-BlasterII [1-1] 031820DD 10M08SA(.|ES)/10M08S(C|L) 02E120DD 10CX220Y tetto@ubuntuoffice:~/mytrial1$ icpx -fsycl -fintelfpga fpga_add2.cpp -Xshardware -Xstarget=Cyclone10GX -o fpga_compile.>aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to> tetto@ubuntuoffice:~/mytrial1$ ./fpga_compile.fpga terminate called after throwing an instance of 'sycl::_V1::runtime_error' what(): Invalid device program image: size is zero -30 (PI_ERROR_INVALID_VALUE) Aborted (core dumped)
