oneAPI on Cyclone10gx
Hi @StefanoC,
Thank you for posting in Intel community forum on your interest in oneAPI and hope all is well.
If I understand the situation correctly it seems that you are trying to run the hardware compilation in the IP authoring flow, and based on the error message it complaining that device not found.
Hence suspecting that the command line used might be incorrect, for that you may refer to the compilation flags below:
Hope that clarify
Best Wishes
BB
I was following this:
and indeed I can compile with make (both emulation and fpga), the issue I experience is at runtime, when I try to execute the ./simple-add-buffers.fpga (previously I had issued cmake .. -DFPGA_DEVICE=cyclone10gx to really target my device).
Overall, I have a dual boot computer with windows10/ubuntu, on windows10 I was able to compile and download a sample vhdl to the fpga, so I am sure the board is powered ok/jtag cable is ok too, I am wondering if on ubuntu any additional driver/os related has to be installed. At the moment I have quartus prime (licence is ok) and oneAPI (on both windows10 and ubuntu). I would prefer Linux as I am more comfortable with command line, but I think I am missing something how to get the Cyclone 10gx board properly installed (my understanding was Quartus prime pro contains the cyclone10 driver..), what should I check to make sure my fpga is configured properly on my linux system?
thanks!
