StefanoC
2 years agooneAPI on Cyclone10gx
Hi all, the official Intel fpga requirement page says the Cyclone10gx fpga is supported by oneAPI so I downloaded the latest version on my Ubuntu20 (Quartus Prime also installed), I tried to compile...
BoonBengT_Altera
Moderator
2 years agoHi @StefanoC,
Greetings, to update the compilation flag are able to be completed successfully from our end. Hence suspecting that just the compilation flag that are causing the error. Notice that the used compilation are obselete, please use the xstarget instead.
Hope that clarify.
Best Wishes
BB
- StefanoC2 years ago
not sure I understand what you wrote, did you try to compile using the same compilation flags I used? If you are successful then the issue is not the compilation flag but some libraries or environment variable? You mention xstarget, is there any documentation?
