hps debug
37 TopicsIntroducing the Altera Community AI Responder — Beta
Altera is introducing the AI Responder, an assistant built into the Altera Community to help provide faster, context-aware guidance for Altera product questions. It uses relevant public Altera documentation and Knowledge Database content, with coverage continuing to expand. The AI Responder may provide source references and can hand off complex or out-of-scope questions to an Altera subject-matter expert. As a beta feature, responses may contain errors or omissions, so please review the sources and verify technical guidance against official Altera documentation before implementation. If the response does not fully address your question, add more context and tag ai_responder to continue the discussion. We welcome your feedback as we improve the Community experience.19Views0likes0CommentsRelease 26.1.1
Version: Release 26.1.1 PRO Quartus Build/TAG: B130/QPDS26.1.1_REL_GSRD_PR Release Date: August 17, 2026 Device Affected: Agilex™ 3, Agilex™ 5, Agilex™ 7, Startix® 10 Release Type: Major release/Binary release Binary Release Path: http://releases.rocketboards.org/2026.08/ Release Page: https://github.com/altera-fpga/gsrd-socfpga/releases/tag/QPDS26.1.1_REL_GSRD_PR Major Features Released Agilex™ 5 XEN Hypervisor 5 System Example Design https://altera-fpga.github.io/rel-26.1.1/virtualization/hypervisors/xen/ug-xen-agx5e-premium-065b/ , https://altera-fpga.github.io/rel-26.1.1/virtualization/hypervisors/xen/ug-xen-agx5e-premium-065a/ Agilex™ 5 RYO OPTE System Example Design Agilex™ 5 Quartus Reference Design using VDS Agilex™ 3 Time-Sensitive Networking (TSN): PHY configuration 2 (RGMII from FPGA HVIO) System Example Design Agilex™ 5 Performance Optimized Baseline SED support Agilex™ 5 DataMover / Bridge and Memory Benchmark System Example Design https://altera-fpga.github.io/rel-26.1.1/embedded-designs/agilex-5/e-series/premium-065a/data-mover/ug-data-mover-agx5e-premium-065a/ Agilex™ 3 support of FreeRTOS Agilex™ 5 Terasic DE25-Nano Board System Example Design103Views2likes0CommentsUSB Device Issue on Cyclone V / HPS
Hello, Please find below a description of the USB issue we are experiencing with our Cyclone V / HPS board. To test our USB interface, we integrated the TinyUSB library into our existing firmware and enabled FreeRTOS support. Since the Cyclone V is not natively supported, I implemented the missing functions using Altera's hwlib, which we already use in our project (source file attached). The USB is used only in Device mode. I tested the following four configurations: Full-Speed with Slave mode Full-Speed with Simple DMA High-Speed with Slave mode High-Speed with Simple DMA The behavior is identical in all four cases: Connecting our board to a Windows or Linux host is correctly detected. The SETUP transaction is successfully received, and the host receives the device descriptor in response. When the IN transfer complete interrupt is triggered, the USB controller is configured to receive a zero-length packet on OUT0. However, the USB protocol analyzer shows that the device continuously responds with NAK to this packet. The host retries for approximately 5 seconds, but the device keeps responding with NAK. The register values immediately after configuring the reception of the OUT0 packet are: Gotgctl = 0xd00c0 Gintsts = 0x4000020 (PTxFEmp, NPTxFEmp) Gdfifocfg = 0x1f802000 Dctl = 0 Dcfg = 0x8100001 Dsts = 0x18702 Doepctl0 = 0x80008000 Doepint0 = 0 Doeptsiz0 = 0x80000 Grxfsiz = 0x50 After a few milliseconds, I observe that DOEPINT0.NAKINTRPT = 1, which seems to confirm that the device is sending NAKs. However, I do not understand why the OUT packet is not being accepted, since the receive FIFO is not full and both DCTL.GOUTNAKSTS = 0 and DOEPCTL0.NAKSTS = 0.Solved386Views0likes17Comments2.5G Ethernet Reference Porting inquiries.
Hi, guys~ My customer wants to use the 2.5G Ethernet feature, but unfortunately, they purchased the Agilex5 Premium Kit instead of the Modular Kit. I am currently following the R&D guide with them, but the 88E2110 is not being recognized properly. Which parts should we check? First, I followed below link. And have built the Reference Design boot images. https://altera-fpga.github.io/rel-26.1/embedded-designs/agilex-5/e-series/modular-065b/tsn/sgmii_xcvr_3x2.5G/ug-tsn-sgmii-xcvr-3x2.5G-agilex5/ Second, I regenerated the hardware image after updating the Modular design pinout to match the Premium Kit specs. In the Premium schematic, the 88E2110 PHY reset pin is connected to the FPGA, but there was no control logic applied. So, I added logic to release the reset after 20 ms. Third, in the device tree, I enabled emac0 and disabled emac1 and emac2. Since the soft MDIO logic remains unchanged, the addresses shouldn't have changed. However, while the emac0 logs appear, the PHY is still not being recognized. Please refer to the attached boot log. Why did they use soft MDIO instead of the native EMAC0 MDIO? Is this a characteristic of 2.5G Ethernet?Solved202Views0likes5CommentsStratix 10 Linux SD card booting
Hi Altera Community, I tried multiple attempts to boot the SD card from Rocketboard.org. https://releases.rocketboards.org/ I downloaded and booted the SD card with the .wic image file. It only has the .itb file by default in the boot partition. Whenever I try to boot, it asks for the U-Boot.img file. And also it says "failed to load "socfpga_stratix10_socdk.dtb" even if the file is there. And then I compiled my simple HPS design and can easily program the FPGA from the Quartus Programmer (rbf and sof file), but whenever I try to overlay it, like say: echo overlay.dtb > /sys/kernel?config?device-tree/overlays/0/path It says "FPGA manager error, timeout," and so on. Does any community member have notes or steps that you made to boot the SD card of the Stratix 10 FPGA? I am following this link: https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderStratix10249Views0likes11CommentsStratix 10 HPS LED example
Can someone suggest a basic HPS project with PIO for LED control. Need the complete flow of building the project from scratch. How to assign the HPS pins in Quartus. How to add uboot along with fpga pof file in QSPI flash. How to load linux in emmc.Solved572Views0likes19CommentsTimings eMMC
Hi, latest datasheet of SoC « 813918/2026.01.05 » lists in paragraph « HPS SD/eMMC Timing Characteristics » the constraints of eMMC, applicable to memory component but does not define any timing data in input/output of SoC. There is no Tco min/max of CMD/DATA at SoC output, as well as Tsetup/hold of CMD/DATA at SoC input. Can you provide Tco and Tsetup/hold for eMMC usage (Legacy, HS_SDR, HS_DDR, HS200, HS400) ? thanks194Views0likes7CommentsAgilex 5 premium board - es version - boots with gibberish prompts
Hello dear community, I am trying to boot linux on the Altera Agilex 5 premium board - es version with the pre-built binaries. I followed the documentation still getting prompts in gibberish. Following is a detailed description of the procedure I used. My questions: 1. What am I doing wrong? 2. What should be my debugging flow steps? Detailed description of the procedure to demonstrate the issue: --------------------------------------------------------------------- In order to verify the Agilex 5 SoC premium baord is booting correctly, I used the pre-build binaries per the following instructions of this link: https://altera-fpga.github.io/rel-25.1.1/embedded-designs/agilex-5/e-series/premium/gsrd/ug-gsrd- agx5e-premium/#configure-serial-console I followed the paragraphs starting with the title " Exercising Prebuilt Binaries" This page instructs the user to download the pre-built binaries from this release: https://releases.rocketboards.org/2025.08/gsrd/agilex5_dk_a5e065bb32aes1_gsrd/ I followed the instructions of "Booting from SD card". The workstation is Windows 10 machine and the Terminal application is putty. Eventually, when booting the linux per these instruction, I see the first stage boot loader (u-boot spl) is prompting correct font, however the next booting stages are prompting gibberish. Attached is a screenshot (202604262215screenshot.jpg).Solved203Views1like5CommentsS10 hps fpga2sdram bridge low speed
Hello, i have some problems I have a project with stratix 10 with hps I need to use ddr4 with hps, so I enabled 3 fpga2sdram bridges with 128 bit width Via u-boot smc configured and enabled them, but measured speed is not enough. When I use onle one bridge my speed is approximately 32 gbit/s (bridge and master frequency 350 MHz) But when I use all 3 bridges it becomes 20 gbit/s I use avmm bridge to connect to axi fpga2sdram bridge with 128 bits width, max pending writes 16, max burst size 128, use only write to bridge ECC in emif (hmc) is disabled I tried to use QoS for bridges, set them to bypass P.S. If i use the same board with firmware without hps, i get 130 gbit/s (with disabled hps) Quartus Pro 21.4 Any help would be useful!343Views0likes10CommentsSupport Request to Debug Signal Tap Issue with SoC Based Design(GHRD) on Agilex-7 FPGA
Hi Altera Support Team, Greetings from Logic Fruit Technologies. This is Bhanu Pratap and I am working on the project in which we are using Agilex-7 SOC FPGA. Goal: Utilize Agiliex-HPS's capability on a Linux OS to control dynamic features of IP Cores at runtime. Problem Statement: We are facing an issue detecting SignalTap with SoC-based designs for runtime debugging while it's enabled and added from the Quartus project to generate the programming file. Brief Description: We are using Quartus 2025.1.1 and Altera's Agilex-7 Devkit(DKSIAAGI027FA: Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit -> 4x F-Tile, Rev C). We downloaded the base GHRD design from Altera's GitHub webpage for the corresponding Quartus version. We are following each step to test GHRD and build generation for the Linux OS. We are using HPS First booting mode, we generated the build without modification and tested it. It's working fine according to the GSRD user guide. We have added a custom AXI4 Slave based CSR module to the HSP Lightweight bus to test basic register read/write using Platform Designer. We regenerated the build and re-tested but we are not getting the expected results so we added SignalTap for debugging. Build is generated using the STP file, programmed, and the OS is booting but it's not detecting SignalTap. This looks more like a process gap. We seek your support to fix this issue. Note: If we use an FPGA design without HPS, we are able to add and detect SignalTap. Seeking for urgent support. Thanks Bhanu Pratap156Views0likes3Comments
