fpga devkit
901 TopicsAgilex™ 7 FPGA – 25G PON Design Example report 404
Hi, I want to check Agilex™ 7 FPGA – 25G PON Design Example's development-kits: https://docs.altera.com/r/example-designs/775184/current/agilextm-7-fpga-25g-pon-design-example/development-kits But it reprots 404, could someone help me about this issue? Best Regards, Lambert47Views0likes6CommentsArria V GX Starter Kit file download and recovery
Hi, I can not find any Arria V GX Starter Kit files at this link: https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/v-gx.html I would like to download the Starter kit files for board recovery. Do you have a new link/archive where I can download these files, i.e. arriaV_5agxfb3h4_starter_vxx.exe ? Regards11Views0likes2CommentsNeed help to download Arria® V GX Starter Kit
Hi, We're having few Arria® V GX Starter boards in our lab. We want to try to use them lately for few of our POC works. I tried to download the starter kit from here https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/v-gx.html However, the downloading is not happening. Is there anyway, you can make this kit available for me? Regards, Vikram694Views0likes4CommentsAgilex 5 E-Series 013B Development Kit User Guide SW4.2 (spread spectrum) description is inverted
The description of DIP switch SW4.2 in the Agilex 5 FPGA E-Series 013B Development Kit User Guide (ID 860700, version 2026.10.02) is inverted and contradicts the board schematic. User guide (Table 4 "Factory Default Switch and Jumper Settings", Table 7 and Table 17 "Switches"): OFF - enables the -0.5% spread spectrum modulation for the PCIe clock ON - disables the -0.5% spread spectrum modulation for the PCIe clock Schematic (a5e013b_soc_dk_schematic_v1p0.pdf, sheet 51 "CLOCK GENERATOR - SI5332 DECAPS", SW4 table): POS2 ON - SPREAD SPECTRUM = ENABLE POS2 OFF - SPREAD SPECTRUM = DISABLE (default) I tested this on the board, and the schematic is correct: OFF - spread spectrum disabled (factory default) ON - spread spectrum enabled The GTS PMA/FEC Direct PHY TX PLL real-time lock status did not report lock on the PCIe reference clock PCIE_EP_REFCLK (pin M24) with SW4.2 ON. With SW4.2 OFF it reports lock.Solved41Views0likes3Commentscurrently evaluating FPGA solutions
Dear Intel FPGA Team, Greetings from PARAS Defence and Space Technologies. We are currently evaluating FPGA solutions for our C-band SATCOM terminal project. Our key application requirements are as follows: RF frequency range: 4.4–4.95 GHz • Instantaneous RX bandwidth: 16 MHz • RF channels: 4 RX and 4 TX • Interface: JESD204B/C between the RF transceiver and FPGA • Application: Ground-based SATCOM terminal for tracking a moving aircraft We are considering the Intel Arria 10 FPGA family as a potential platform and have reviewed the available reference design for the ADRV9029 Sub-6 GHz evaluation board with Arria 10 FPGA. To clarify the technical feasibility and plan our development and procurement activities, we would like to arrange a meeting with your FPGA technical and sales teams to discuss the following topics. FPGA Selection and Compatibility Recommendation of a suitable Arria 10 or other Intel FPGA family and specific part number for our application, considering JESD interface requirements, FPGA resources, transceiver capabilities, and future scalability. ADRV9029 JESD204 Integration Confirmation of the supported JESD204B/C configurations, available transceiver lanes, achievable lane rates, and relevant FPGA IP requirements for interfacing with the ADRV9029. Reference Design and Porting Support Guidance on the available ADRV9029–Arria 10 reference design, required hardware platform, design files, software dependencies, and the feasibility of adapting the reference design to our intended FPGA platform. Development Tools and Technical Support Information on the required Intel Quartus Prime software edition, JESD204 IP licensing, simulation resources, design examples, and technical support available during FPGA development. Evaluation Hardware Recommendations for a suitable FPGA development kit or evaluation platform for initial ADRV9029 integration, including availability, compatibility, and procurement options. Product Presentation A technical presentation covering relevant FPGA families, high-speed transceiver capabilities, JESD204 interface solutions, design resources, and application examples suitable for RF and SATCOM systems. Procurement and Commercial Discussion Indicative pricing, product availability, lead times, development kit costs, and long-term supply considerations for prototype development and production. We would appreciate the opportunity to discuss these requirements with your technical specialists and sales representatives at a mutually convenient date and time. Please let us know your availability and whether any additional technical information is required from our side before the meeting. Thank you for your support. We look forward to your recommendations and to working with your team to identify a suitable FPGA solution for our project.117Views0likes6CommentsAgilex 7 AGIB027R29A1E2VC board QSFP-DD issue
We have Agilex 7 AGIB027R29A1E2VC board which has two 8-channel QSFP-DD ports, both are connected to F-TILE Bank 12A. QSFP-DD Port B is connected to FGTL12A_Q2 & Q3, while QSFP-DD Port A is connected to FGTL12A_Q1 & Q0. We have a QSFP-DD A port project (4 x50G PAM4 settings), we got error when compile it, as shown in the attached figure. If I change the pin assignments for Port A to those of Port B in the .qsf file, the compilation succeeds without any issues. However, compiling with Port A's original pins fails. I'm not sure why it happened and how to fix it. Can anyone help check this issue? Thanks in advance!124Views0likes6CommentsInstaller Package for DK-DEV-10AX115S-B
The Obsolete Arria® 10 GX FPGA Development Kit | Altera revision -A came with an Installer package: The Arria® 10 GX FPGA Development Kit | Altera revision -B is missing this: Can you please provide similar resources? Best regards, Nikolay92Views0likes2CommentsDE2-115 Nios VGA demo
Hi , I am trying to run an VGA demo on DE2-115 board , i followed this document attached which is final univ project(see attached). But after successfully generating and compiling Quartus ver 18.1 project and then its related software in Nios-ll Eclipse IDE i get this error "Downloading ELF Process Failed. See Quartus Project attached. Thanks, Regards168Views0likes8CommentsAXE5-Falcon using the J8/J9 MIPI connectors?
Is there a MIPI reference design or other public available design for the AXE5-Falcon using the J8/J9 MIPI connectors? I keep getting RZQ_GROUP type of errors whenever I use the B2A differential ref clock and the DP58/RZQ_B_2A pin.Solved125Views0likes4CommentsBoard Test System Download Package – Stratix 10 TX Signal Integrity Development Kit
Hello, I am currently working with the Stratix 10 TX Signal Integrity Development Kit on a Windows PC and would like to use the Board Test System (BTS) to verify the functionality of the board. According to the Stratix 10 TX Transceiver Signal Integrity Development Kit User Guide, the BTS application should be included in the development kit package under: <package_dir>\examples\board_test_system\BoardTestSystem.exe However, I have not been able to locate the appropriate BTS package or download containing the BoardTestSystem.exe application. Could someone from Altera please provide the current download link or the appropriate installer/ZIP package containing the BTS application and its associated test designs (.sof files)? I would also appreciate confirmation of the recommended Quartus Prime version and any required dependencies for running the BTS on Windows. Board: Stratix 10 TX Signal Integrity Development Kit Development Kit: DKSI1STXEA Host OS: Windows Thank you for your assistance.590Views0likes9Comments
