Knowledge Base Article
Why is there a mismatch in the FFT Intel® FPGA IP output result in simulation between the IP-generated MATLAB* model and the HDL model?
Description
Due to a problem with the FFT Intel® FPGA IP version 19.1, you may observe the above problem in the simulation if the Data Output Width of the IP is not configured to the maximum supported width.
Resolution
To work around this problem configure the Data Output Width to the maximum supported width in IP.
This problem is currently not scheduled to be fixed in a future version of the FFT Intel® FPGA IP.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
