Knowledge Base Article
Why does the processor connected to Nios® V Debug IP remain halted after executing “monitor swreset 1 0” in Ashling* RiscFree* IDE 26.3-B?
Description
Due to a problem in the Ashling* RiscFree* IDE software version 26.3-B, executing the following command may leave the processor halted instead of running after the processor is reset, for designs targeting Nios V processor connected to Nios® V Debug IP.
monitor swreset 1 0
From ash-riscv-gdb-server –-help:
monitor swreset <reset mode> <halt> <hart id> - Issue a software reset.
<reset mode> |
<halt> |
1, NDM(Non-Debug Module) reset |
0, Do not halt after reset |
2, Reset harts only |
1, Halt after reset |
3, Reset specific hart <hart ID>. <hart ID> is indexed from 1 |
The <halt> argument of 0 specifies “Do not halt after reset.” However, the processor has stopped immediately after Ashling* GDBServer asserted the software reset thru Nios V Debug IP.
This is an issue in the affected Ashling* GDBServer.
Resolution
To work around this problem in the Ashling* RiscFree* IDE software version 26.3-B, switch to OpenOCD (such as applying “-o” argument with niosv-download)
This problem is currently scheduled to be resolved in a future release of the Ashling* RiscFree* IDE Software.
