Knowledge Base Article
Why does the HDMI Design Example fail to generate when using the Quartus® Prime Standard Edition Software version 24.1?
Description
From Quartus® Prime Standard Edition Software version 24.1 onwards, Nios® II has been removed and is now End-of-Life (EOL).
The HDMI Design Example hasn't been upgraded to Nios® V yet, and so this causes the design example generation to fail.
The error below will be seen when trying to generate the design example for the listed device families:
"Error: Failed to generate example design example_design to: "
Resolution
No workaround for this problem exists.
If necessary, use the Quartus® Prime Standard Edition Software version 23.1 until this problem is resolved in a future release.
Additional Information
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 4 months ago
Version 5.0
