Knowledge Base Article
Why does the DisplayPort Intel® FPGA IP fail to output video when Vtotal of Main Stream Attribute (MSA) field is greater than 13-bit width?
Description
Due to a problem in version 14.0 and later of the Intel® Quartus® Prime software, the DisplayPort Intel® FPGA IP Pixel Clock Recovery Interface Hsync and Vsync signals stick low when the condition below is met:
  • Video resolution with Vtotal Main Stream Attribute (MSA) field exceeding 13-bit width or 8191 in decimal.
Resolution
This problem is fixed starting from the Intel® Quartus® Prime Pro Edition version 20.1 Software onwards.
Updated 2 months ago
Version 2.0
