Knowledge Base Article
Why does Nios® V/c processor fail to service interrupts when it is under CLINT-Vectored mode?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1, the Nios® V/c processor might fail to service any interrupts when it is under CLINT-Vectored mode. The affected interrupts are platform interrupts, software interrupt, and timer interrupt.
The following are not affected by this issue:
  • Nios® V/c processor under CLINT-Direct,
  • Nios® V/m processor, and
  • Nios® V/g processor
This is because the Board Support Package Editor fails to generate relevant macros in system.h to support CLINT-Vectored mode.
Resolution
To continue using CLINT-Vectored with Nios® V/c processor, add the following macros in the system.h.
#define ALT_CPU_INT_MODE 1  #define NIOSVSMALLCORE_INT_MODE 1  #define INTEL_NIOSV_C_0_DM_AGENT_INT_MODE 1
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software version 26.1.
Updated 3 days ago
Version 2.0
