Knowledge Base Article
Why does downloading ELF file into Nios® V/g processor fail when disabled branch prediction, while enabled instruction cache?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1, downloading ELF file into Nios® V/g processor might fail when both the conditions below are fulfilled.
  • Branch prediction is disabled, and
  • Instruction cache is enabled
The niosv-download command returns the error message below.
Unexpected vCont reply in non-stop mode: E30  ERROR: GDB failed.
This is because there is an RTL bug in the instruction cache related to its reset state.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 25.3.1,
  • Either enable branch prediction,
  • Or disable instruction cache
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software version 26.1.
Updated 9 months ago
Version 3.0
