Knowledge Base Article
Why does Board Support Package (BSP) Editor in Quartus® Prime Pro Embedded Edition fails to generate Nios® V processor BSP project from .vds file?
Description
Due to a problem in the Quartus® Prime Pro Embedded Edition Software version 26.1 and 26.1.1, the BSP Editor fails to generate Nios® V processor BSP project from .vds file.
This issue is not affecting BSP project generation:
- From .qsys file using BSP Editor in Quartus® Prime Pro Embedded Edition software, or
- Using BSP Editor in Quartus® Prime Pro Edition software.
This issue is caused by a software bug in the BSP Editor of Quartus® Prime Pro Embedded Edition software.
Refer to Nios V Embedded Processor Design Handbook - Recommended Tools from Quartus Prime Installer (PDF) for more information on the difference between Quartus® Prime Pro Edition and Quartus® Prime Pro Embedded Edition software.
Resolution
To work around this problem in the Quartus® Prime Pro Embedded Edition Software version 26.1 and 26.1.1, apply either one of the workarounds below:
- Switch from .vds to .qsys file
- Use BSP Editor in Quartus® Prime Pro Edition software version 26.1 or 26.1.1
This problem is currently scheduled to be resolved in a future release of the Quartus® Prime Pro Embedded Edition Software.
